tach stuck
t8764
I tach is stuck at about 500rpms when the boat is off.
Anything that I can do?
Silvertip
Re: tach stuck
If the tach goes to zero when the key is turned on, then it is not an issue. Many gauges "float" at other than zero when turned off. If it doesn't go to zero when the key is on, then there is a tach issue.
