I tach is stuck at about 500rpms when the boat is off. Anything that I can do?
T t8764 Cadet Joined Oct 4, 2009 Messages 29 May 18, 2010 #1 I tach is stuck at about 500rpms when the boat is off. Anything that I can do?
Silvertip Supreme Mariner Joined Sep 22, 2003 Messages 28,771 May 18, 2010 #2 Re: tach stuck If the tach goes to zero when the key is turned on, then it is not an issue. Many gauges "float" at other than zero when turned off. If it doesn't go to zero when the key is on, then there is a tach issue.
