TACHOMETER ACCURACY
phx5kegsman
I have a 1978 Johnson 115hp V4 crossflow. I'm having issues with my Tachometer. It seems to be accurate up to around 2000 rpm. But, when I push the throttle down tach climbs to around 7200rpms, and I'm not even at WOT yet! I think WOT should be around 5200 on my motor. Obviously, my tachometer is not accurate. Any suggestions WHY?
Berdink
I know you know your tach may be off, but to check it you can do a loan a tool from AutoZone, or other local auto parts store, and see if they have a timing light with the included tach.
Then at least you'd know how far off it is.
In my searching for a tach, I read older ones can be off.
A cheapo inductive one is said to even be more accurate than older factory tachs.
saltchuckmatt
Is this a "new to you" tach? Pulse settings correct?
Chris1956
Is your prop slipping? Buy a new tach and try it. They do not last forever.
Chris1956
It probably makes sense to check and clean your wiring to the tach, especially the ground.
phx5kegsman
The tachometer is 4-5 years old. The brand is Faria. I did buy a handheld tach, but it's useless out on the water. You have to put a piece of reflective tape on the flywheel and aim the tach at the tape from less than 12 inches away. It's useless while driving the boat. I have a timing light, but it has no tach. I have yet to figure out how to check my timing, although, I'm sure that I should. I have replaced ALL of the ignition components over the 6 years I've owned this motor. The manual says to check timing with the engine speed "set to 4300-4600 rpm (in gear)". I have yet to figure out how to accomplish that by myself. I have seen some small digital tachometers online. I think one brand name is TINY TACH. Has anyone had any experience with one of these?
saltchuckmatt
You need a test tank and prop to do that accurately.
saltchuckmatt
Just cus I have to ask, it's not overrevving from a bad prop or anything? Otherwise, tachs die, rectifiers on you engine go bad and what got me recently...a bad ground on my tach.
Chris1956
Joe Reeves published a timing method for Johnnyrudes, on this forum I believe it did not involve actually running the motor at high RPM to set the max spark advance.
