TwoBallScrewBall
- Sep 14, 2003
- 1,695
Hi all,<br /><br />Just ironing out the little bugs I'm finding in my 'new-to-me' boat. <br /><br />I noticed this last fall when I had the boat out after buying it, and would like to troubleshoot it now that the "nicer" weather is coming.<br /><br />Anyway, the issue is that at times, especially immediately after startup, the tach on my boat (1997 wellcraft, 1997 Evinrude Ocean Pro) will read high, about twice as high as it should. For example idle will read about 2000R when the engine is obviously actually around 1000R. If I tap on the face of the tach it will drop down to where it should be and functions normally until the ignition is shut off again. Sometimes it works fine from start to stop. I've quickly checked the connections on the back of the tach and they're snug. <br /><br />Do I need a new tach?
