taking off lower unit, need help!!!!
jonnymarquis
i have the book but i guess ill need to buy a gasket kit first? so if indeed i do need to buy a kit where can i find the kit and whats i t specifically called for my specific motor? 125 hp 1927 evinrude #125283R. Ty I'm also ordering the type C gear lube as well. ty for the help
kenmyfam
Re: taking off lower unit, need help!!!!
Slow down a little !!!:)
What are you trying to do exactly ???:confused:
Gasket kit for what ???:confused:
1927 motor ???:confused:
What work are you wanting to do ???:confused:
bktheking
I'm thinking 1972 and ya, what are you trying to do?
F_R
125283R is the model number for a 1972 125hp. Gaskets, seals, and Type C are all available right here at iboats.
jonnymarquis
yes i did mean 1972 i was typing to fast sorry. i am going to take off the lower unit to change the impeller, what i was wanting to know is what gaskets am i going to need to change once i have it off before i put it back on. yes i did find the gear oil on here but was needing to know what if any gaskets i should get before i get started. also while i have you here i noticed some black sticky oil on the grass below the prop, about a the size of a playing card. and it was coming out from the little crack between the prop and the lower unit. i really don't know what this could be and if you may know how can i fix it? thank you so much for all the help from you guys, i love this site and all the help from it.
bktheking
There are no "gaskets" per se that you need to replace, go get yourself a complete pump kit , it will come with the orings and all the stuff you will need to put it back together. The black sticky oil is unburnt 2 stroke oil running out after running the motor, pretty normal for that to happen.
jonnymarquis
i cant find the whole kit for that specific motor anywhere. but i do have anew impeller
Fisherball
Go to iboats "Boat Motor Parts" tab, you'll eventually find complete parts schematics for most Evinrude LU's & links to the parts catalouge.
wilde1j
Have you tried a BRP (Johnson/Evinrude) dealer?
a70eliminator
If your just changing the impeller nothing is needed, the gasket is under the plate that you won't be disturbing, just pull the housing and old impeller off the shaft, put the new impeller in the housing and slip it back down in place making sure the impeller's slot matches up with the shaft key.
If the wear plate is good (not all scored up and grooved) then no need to replace it.
