I had a 1998 Volvo penta 5.0gipbycce. I replaced that with a gm 5.7 but all the exhaust system is the same including manifolds, risers, y pipe, etc. I'm thinking of going to the taller risers as recommended but I'm having a hard time understanding the bulletin explaining exactly what I need. I dont think that the taller risers will fit because the angle from the risers to the y pipe isn't 90 degrees so if I go up 3 inches it won't line up. Does anyone have any experience in this and can you give me additional parts that may be needed including part numbers? Best I can figure is that in addition to the risers I may have to replace the y pipe and/or the elbow coming off the risers to get it to line up. As far as the bulletin it states that configurations are also based on the outdrive. I have a DP-sm outdrive.
Thanks in advance.
Thanks in advance.
