Tamd22 turbo PSI and EGT Temps.
jw2000uk
Hi everyone. I have a boost gauge installed, just wonderd what the correct psi is at WOT. I did the vaccum pump test as per manual. Its 19.5psi, but it works out around 14psi on a boost gauge? Regarding EGT. I installed the probe on that black dot. In turbo housing, im getting 720c at near wot. Is that ok? I understand temps are not 100% accurate there, although it is near the exhaust ports tbf
