Jerry_NJ
- Aug 23, 2010
- 250
I saw such a great response to the post on "technology" so I decided to include that in my title, it fits.
I have a 1997 9.9 hp, as you know no battery. I am having a no spark problem.
As this engine has an electronic ignition, it has a "Power Pack", there is, I assume, no magneto high voltage involved. Still, I assume the flywheel/stator has two ignition functions:
1) timing, when to fire the plugs
2) electrical power to power the Power Pack
So, when one pulls the rope, is electrical energy delivered to the Power Pack as well as a fire signal sent from a magnet on the flywheel?
I assume both plugs fire, only one being in the ignition/power stroke, the other piston being on the return/compression stroke. Is that correct? I guess that has nothing to do with my question..but interested any way.
As posted earlier, my dual coil has 0.28 ohms to ground on each coil, measured with the spark plug wire removed. The signal wires (one orange with a blue trace, the other solid orange) terminals on the coil housing both measure continuity to ground (wires removed)... I assume that is a problem. I add this as it is the reason for my current interest in the ignition system, for which details schematic information seems unavailable.
Can someone who owns a 1996 or newer 9.9 Evinrude find the time to measure the resistance to ground on the 4 terminals on the coil assembly - or simply tell me where to find it, or just what it is from knowledge?
Thanks
Thanks
