I have a 1979 150hp merc that hasn't been run in about 4 years. Fired it up today but ran for only about one minute as there was no water at the tell tale. Should water come out the tell tale as soon as the engine fires or does the thermostat have to open first? Could the pressure relief valve be stuck closed? Will install new pump impeller this week and try again. I dropped the lower unit and tried to blow air up to the powerhead through the water tube but seems blocked. Any thoughts??
