Faztbullet
- Mar 2, 2008
- 15,931
I would replace the gasket below the water pump base, which is the part the water pump sits on. Another problem can be the gaskets between the powerhead and adapted/exhaust plates. They can leak and exhaust gas will mix with the water jacket causing overheat.
Make sure you have the right temp alarm sensor. Mine sets off at 243 degrees but it is in the cylinder head touching metal. If your sensor is actually in the water jacket touching water it should be much lower, 160-180 I would think.
