temperature sender stuck in manifold?
Finnerty
I'm afraid to force it in case it breaks off - what's the remedy if it does??
Don S
Re: temperature sender stuck in manifold?
Depends on where it breaks. If it breaks off flush with the manifold, it would be a drill out and retap. Being as it's normally an 1/8" pipe thread, I would drill it out a little bit, just enough to use the largest EZ out possible and still have some meat on the sides of the piece in the manifold.
coheej
I may be wrong. If it's a sb chevy, it's probably a 3/8" to 1/2" pipe. If it hasn't broken yet; try using a 6 pt socket, not an open end wrench. If you can't get a socket in there because of the sender wire then try a wrench made for removing hose type connectors. And if it breaks or is already broken, see Don's post.
Don S
No, you aren't wrong, just somewhere in my typing I turned it into an oil pressure sender. :redface:
454 Mercruiser MIE 330
Ayuh,..... 'n if it's Bad enough,...Replace the T-stat Housing....
Worst case scenario,...
You replace whatever it takes, after you take it apart far enough to find usable motor..
I'm guessin' it's a Saltwater motor,..??
DianneB
If you can lay hands on a little diesel fuel or #1 stove oil, put a couple of drops on the threads every day for a week. Then use a socket and breaking bar and just tap on the bar with a hammer. Take your time, start lightly and SLOWLY increase the force of the hammer blows. It is amazing what will come out.
(I have rebuild a LOT of very old machinery and if stove oil and impact doesn't get it out, it isn't going to come out.)
Finnerty
Thanks y'all, I'll give er a try...
Dave
PitchFork
I'm confused and maybe it does not matter. My Temp Sender is on the manifold and always has been since I bought the used boat. My Temp Switch is on the Starboard Side of the TStat Housing.
Should I relocate my the Temp Sender to the Port Side of the TStat housing?
It sounds like Finnerty has the temp sender on the manifold. I guess it depends on what TStat housing you have on your boat?
Finnerty
or more like it I don't know the difference!!! Either way they both need replacing and I suspect both have been in there a long time...cheers
