HappierWet
Master Chief Petty Officer
- Sep 11, 2008
- 839
What should I be looking for on an OMC stringer powersteering cooler to determine usability? Just look for rust or pressure test or what? Thanks in advance.
If in doubt i would replace the unit. If you get seawater in the ps componets their done.
I'm redoing the power on an 83 celebrity. The block and exhaust manifolds were cracked... I don't have any reason (yet) to think the PS cooler is bad but, I want to look at it before it goes back together. If it's only going to have a few PSI in it...that' s real easy. I thought the PS pump kept the system higher... more worried about steering fluid into seawater. Does that make sense or am I thinking backwards?
I'm guessing here but its probably on the return side of the system which should only be a few psi vs 1000-2000psi of high pressure side.
