I have a 1990 Merc 135hp (On a 20ft Bayliner Trophy) I replaced the water pump but suspect it is not working correctly. I replaced the thermostats, popit valve and installed a water pressure gauge. At idle the water pressure gauge barely registers maybe 1 to 2 lbs it does go up when I increase the RPM over 1500. The water coming out the pee hole (after it's full warmed up) is only a very week stream as opposed to past outboards I have owned. The temp alarm goes off 2 min after the first take off of the day, I shut in down for 2 min then it is fine for the rest of the day. I did install a temp gauge but have not had it out to see if it is overheating or a faulty reading by the sender.
How can I confirm my water pump is working correctly? What is the correct operating temp range for this outboard?
Any tips would help.
Thanks
Thanks
