Maybe there a few left who still use the VRO for oil mixing.
If you do so, it's crucial that the VRO alarm is functional. So the alarm should be checked on a regular basis. This is normally done by running the engine from premix fuel, pulling the oil hose, and waiting for the alarm tone to come. But this introduces a new possible failure source and thus the engine needs to be run from premix until proper oil consumption is verified.
My suggestion is to trigger the VRO alarm electrically. This can be done with the following very simple circuit (just a few $). You don't even need a printed circuit board.
Test procedure:
1. If the engine is hard to start, start engine and warm up a little to make it start easier later. Stop engine again.
2. Turn the key switch in run position. The normal initial tone should sound.
3. Connect the alarm tester shown above to +12V (red or red/purple cable) and the tach signal (gray). After about 15s the VRO alarm should sound (very quick tone, because the inserted tach pulses are 500Hz = 5000rpm). Disconnect the alarm tester again.
4. Without turning the key switch back (as this would reset the alarm), start the engine and let it idle. Now the alarm tone should be the typical 1/2sec on and 1/2sec off tone.
5. With the next VRO pump stroke (latest after 1 minute) the alarm should stop.
Test done.
Test procedure:
Test done.
