testing with DVA adaptor
Ranger 330V
I ordered a CDI DVA adaptor for my voltmeter the other day. I also have a OMC sevice manual. Do you go by what they say in the manual on testing with this adaptor and new volt/multi meters or is there a different setting for use with the DVA adaptor? I know resistance, continuity, and such but do you do anything different with the adaptor or is just a stand alone in-line unit and you do everything the same? Thanks!
seahorse5
Re: testing with DVA adaptor
All you have to do is set your meter to DC volts and to the correct range that you will be measuring.
Ranger 330V
thanks, I just got my adaptor in and my compression gauge..I'm going to work on her now...redoing ignition...well rewiring everything now...will update later...hopefully have life by the end of the day!!
