Texas state law, CROSS YOUR TRAILER SAFETY CHAINS!
H20Rat
Re: Texas state law, CROSS YOUR TRAILER SAFETY CHAINS!
I use chains (crossed) because they do keep a trailer under control at slow speeds and because the law requires me to use them.
What happens, is that the trailer whips back and forth very violently.
I have a very firm grasp of the physics behind it, and my theory is that crossed chains will actually induce that violent action, and may be MORE dangerous than not crossing it. I've talked to a small number of people who had trailers come off, every one that I know who crosses their chains have always had that sway happen. The one guy I know that dropped a trailer without crossing had zero issues, it was dragging on the pavement and bashing into the undercarriage of his truck, but it stayed completely straight.
Think of it this way, due to road forces and drag, you will NEVER have both chains pulling equally all the time. The trailer will always have more load on one or the other. So what happens is that with inequal chain load, the trailer tongue will get pulled in one direction. This immediately causes the tension to drop, and the other chain to load up. Instant problem! And there is no damping in the system, it will build up relatively quickly until something breaks or you are wheels side up.
The IDEAL situation would be to have your safety chains not crossed, and attached as far apart as possible, both on the tow vehicle as well as the trailer. If you had an attachment point 3 feet apart on each end, you could tow that down the highway with no sway issues at all. It would be self correcting, and would automatically dampen out any sway. This would obviously be a big problem when you actually wanted to turn though, so you need a compromise. Keep your trailer mounting point narrow, but widen out the vehicle side, again, not crossed.
Anyone got an old truck, old trailer, and a big open paved area to test it out?
smokeonthewater
actually the biggest cause of whipping back and forth is low tongue weight.
Texas Parrothead
OK, so I'm scared! My 93 Chaparral came with a roadrunner trailer made for the boat.
It only has 1 chain and came from the manufacture like that!
npd4432
Sounds like a good suggestion to make to the Mythbusters
109jb
I seriously doubt that the trailer was manufactured like that. In any case, just go get another safety chain and add it to the trailer.
HappierWet
Master Chief Petty Officer
LOL
He wants to use somebody else's stuff to test HIS theory. LMAO
I would suggest that with your "very firm grasp of the physics behind it", that you test with your equipment :rolleyes: Preferably with pictures, or even better video:D
Minnesota seems to be in the minority, in that the vehicle code only requires chains not that they be crossed. I am not going to check all 50 states, but I have checked the ones I tow in, they ALL require crossing. I guess maybe the traffic safety engineers might know what they're talking about.:p
Willnott
If you take a quick look at the geometry, crossed chains also allow the chains to be shorter (with better control) without binding when turning.
Actually, you really DO need to look at the geometry, because many, many trailers, boat and otherwise, attach both chains at ONE POINT. In such case (which is the case with my boat trailer, AND my utility trailer) crossing the chains has absolutely NO EFFECT. It will not form the "desired cradle". The problem is the "law" (*and* my personal experience with less than astute LEOs) simply can not comprehend this geometric fact. Any trailer that has a "single beam tongue" has only one point at which to attach the chains. Both lawmakers *AND* LEOs need to become better informed. I have resolved that the next time a LEO mentions this to me I will ask them to demonstrate how to cross the chains when they are attached at the same point. Every informed boater and trailer user should do the same.
Willnott
And do what? Attach it at the same point as the other one? In fact where else CAN it be attached. NOW, think about it - you have two chains attached to the same point - how will "crossing" them form a cradle??? Physics and geometry do not lie - you might be able to twist them some, but they will never form a cradle. A cradle is only ever formed if chains are attached at somewhat separated lateral points.
Now, why don't you go and teach your less than erudite legislators a lesson in geometry?
Frank Acampora
My son was given a ticket for not crossing the chains here in Pa. The chains were both bolted by one bolt, at the same point, to the trailer tongue. He did go to court and plead innocent. The cop argued but the judge interjected: "I have a jetski trailer and the chains are both bolted to one bolt at the same point--case dismissed!"
AND--Many years ago, my friend dropped a trailer at 60 MPH. Chains held but by the time he stopped the ground loop was worn away.
Anyway, crossing safety chains should be like seat belts. You should not need a law to require it. You should just do it because it is smart and cheap insurance. I totaled a VW before the advent of seat belt laws but the bug had seat and shoulder belts which I was wearing. Shortened the car by 2 feet, took out three sections of guard rail and clipped off a 6 inch tree. I walked away with no injuries at all. That one use paid for all the times I wear them and don't have an accident for the rest of my life.
Thalasso
You do know, the thread is two years old????
roscoe
Its really not that hard.
You use a bolt thru the tongue or the back of the coupler.
You attach one chain to each side.
You cross the chains under the coupler, several times if needed to shorten up the chains.
I think you can do it, give it a try.
The real hard part is to find an attachment point on the tow vehicle, that is high enough to keep the tongue off the ground if it should become uncoupled.
lamphega
I have always beefed up my chains when getting new trailer with threaded D clips on end. And when a coupler let loose at 60+ on the interstate I kept my trailer behind me and was able to stop with no damage except to my nerves. Could feel that baby yank and crank but I didn't lose it. Snailed my way to off ramp and redid coupler. Another time in winter snow driver in front of me spun out. Got truck and trailer 95% past then she spun back into my lane and my trailer wheel hit her car, ran right over the front fender and hood. Broke the coupler, wheel, axle and all. Had a few seconds of terror as I went off-roding into median. When I finally stopped trailer still connected. Trailer had to be towed that time but Wife and I got home safe. We shook for about an hour but we were safe, Thankfully so was other driver. Some people might say I am overly concerned with safety. No such thing is my motto.
jbetzelb
OK I will get on a 2 year old thread. I have always crossed my trailer chains except my boat trailer. It has two chains connected at one point on the trailer. After I thought about a single connection point it kind of made sense. If it drops off the ball those two chains are going to kind of lock the toung in between them. Once it slams up under the back of the truck it wouldn't let it sway more than about 6 inches either way. Single connection point seems to allow for shorter chains. They are connected about a foot behind the ball mount and have enough slack that they clear the bottom of the ball by 2 inches so I can turn both ways with nothing catching.
spyder9179
I'm 36, I've owned a boat for about 8 years and pulled a trailer for lawn mowing for about 8 years.
I've never heard about crossing chains. I'll start today, thx for the post.
Right there with you. I'm 37, and while I'm new to boating, I grew up on a farm, so I've been pulling trailers in some respect for 25 years. Never heard of crossing them. And while you all can debate the merits of doing so, if it keeps me from getting a ticket, that's what I'll do.
Chip Chester
jay_merrill wrote:
"At high speeds, if the trailer comes off the hitch, IMO they are more dangerous than having the trailer separate from the vehicle."
More dangerous to you? Good, it's your trailer. More dangerous to others? No good. The trailer is your responsibility, and if necessary, the albatross around your neck.
Just sayin'.
Chip
Maclin
The chains can be attached at one point on the trailer, but they will (should) be connected to separate hooks on each side of the hitch on the tow vehicle. The length of the chains is one of the factors in creating the proper cradle potential.
scumfrog44
and of course it won't hurt to have a cigar and intern in the truck
when you get busted.
90stingray
My trailer has cables not chains. Should I cross them or replace them with chains?
Mine had the coil'd cables when i bought it... i hated them. Had them as safety cables on coupler and winch safety on the boat. Unbolted those and disposed of them. I welded on chains to replace those cables. Life is good.
Edit: I read thru most of this thread... missed the part that its a two year old thread. Dang. Still good info.
JStrom
Just what we need, more government telling us what we can and can't do. What a waste of taxpayer money.
