Re: The differences between Chrysler 140HP and 130HP ?
A 140 with a small light hull will use a 13 X 21 prop. If the RPM still goes over 5500, then that prop can be cupped or you can step up to a 23 pitch--if you can find one.
The first photo is of my `140 with a 1 piece lower unit on a 21 foot cuddy cabin. This engine uses a 13 X 19 pitch prop and for water-skiing it uses a 13 X 17 prop. In the photo, it has a 13 X 23 bronze Mercury racing propeller.
Just for illustration, the last two photos are of a Force 125 on a 14 foot flat bottom hull.The Force 125 is very similar to the Chrysler 140. That is why I can use it for comparison. This engine uses a 13 X 21 prop and turns 5900 RPM at 60 MPH. This does vary with prop brand: A Ballistic 13 X 21 stainless loads down the engine to about 4700 RPM, but because of increased efficiency (of the prop) speed still remains at 60 MPH. (88KPH?)
SO, a 13 X 21 is a good starting point but you must still experiment.
And yes,I agree. When you can buy an engine very cheaply, total operating cost does go down. It takes a lot of gas saved to make up for the cost and depreciation of a newer engine.
