I recently added a larger stereo system to my boat and was recommended to add a second battery for the stereo. I was directed to buy a perko switch and after purchasing a new battery I dove into the project. My original setup, single battery, engine ground to - terminal, starter to + terminal and a smaller black wire going to the negative post and a smaller red wire going to the positive post. I imagine those wires are for the accessories? Anyways, I added the second battery, wiring the starter cable to the common post on the switch and the starting battery to #1 and house battery to #2. I ran a cable in between both battery - terminals and left the ground connected to the original starting battery from the motor.
The problem is, i’m not untimely sure how to wire the rest. My stereo is currently hooked into the ignition so it only turns on when the key is moved. I wanted the second battery to run the stereo while i’m beached or tied up, but I’d also like to have it on after I start it and cruise around. What’s the best way to wire the amp and the head unit to accomplish this? I’ve tried putting the red accessory wire on the common post of the switch and leaving the smaller black cable on my battery but it only works when the starting battery is selected or when the switch is on both, the stereo
will not turn on at position 2(house battery). If i ran a ground from battery to battery, wouldn’t the smaller black wire still be grounded to both batteries even if it’s connected to just 1? Sorry for the long post, just trying to give you all an idea of what i’m doing wrong! Thanks!
