The engine starts but has problem with idle then not start any more
BoboCano95
Hi, I am new with boat.
I just bought a Jet Boat Sea Ray 1995 F14. I played with it for few hours, around 10 hours, it ran fine without issue.
Then the engine suddenly stopped. I left it for couple days and put the boat into lake again, it ran well for couple hours, then stopped.
Last time, it when I started, it has problem with idle, but still started and run, as long as I don't put it in idle.
It ran about half hour, then now not start any more.
Does anyone know where to look into first?
Thanks so much
jbcurt00
Probably ought to move this topic to Mercury OBs instead of PWC.
Jeff J
Check fuel pressure and/or try pumping up the primer bulb if it has one. Saw a Mercruiser a while back that did what you described. The fuel pump was in the process of failing.
alldodge
On the top it says 120HP Mercury Jet on logo
But when I google the serial number, seems 90HP.
It has 4 spark plugs.
Thank for look into it. Any suggestions are welcome.
What is the serial number?
