Re: The hidden secret to sanding - Is there one?
Some excellent info in this thread. Prior to working on the boat hull, I had no idea what was required to make a smooth even surface of a long distance. What an awakening!
Use a wet/dry paper and sand wet it will last longer.
I have found this to be the most monumental improvement in my sanding. Once I got the hull pretty smooth using rough paper, I was able to sand the entire side of the hull with one 2x8 piece of paper, so long as I kept it wet and rinsed it in water often. The grit took forever to wear down and the paper never clogged up. Wet sanding is by far the way to go if you can manage it. What a paper savings!
