FreeBeeTony
- May 15, 2002
- 3,995
Re: The timing on my 165hp IL 6 will not hold..update 07/28
How about testing trhe oil pump with a drill? Before I started my rebuilt IL6 for the first time I "primed" the oil pump with the shaft from another distributor. You should be able to get some (~10lbs) pressure with a cordless drill and this shaft. You obviously do this with the distributor removed. Make sure you have the key on so the gauge has voltage.
