Watermann
- Jan 12, 2013
- 13,827
Doing a little work today, got the side brackets installed that tie the hull sides in to the transom. 4 solids through the hull and attaches by 2 through transom bolts. I thought about going one more bolt for it but the gunnel right above it has a bracket that ties it into the transom and then there's the massive splashwell I've decided to put back in.
Got to the point that I'm ready for the tank to go in so I made up some neoprene padding. There's a drain at the far end in the picture for water to exit into the bilge so all the padding in the chevron pattern facilitates that that flow. (sorry a bit blurred)
I hadn't done much with the fuel tank other than cover all the open filler, vent and feed fittings. So I pulled it out to see what a great job SC did padding the tank as you can see the outline of the strips they had under the tank.
When it came time for a close up inspection of the bottom of the tank I was wondering why there was all the brown stuff, thinking at first it was the legendary SC glue gun guy who made a mess. I realized that it was gas varnish, no reason for it to be there unless there was a leak. I started poking around with a pick taking a close look and to my dismay I stopped counting holes all the way through at 19. The tank is a total basket case from the inside out. Here's a pic of a some pin holes in a cluster. If you scroll back up to the full tank view you can see the spots I cleaned showing the extent of the problem.
