crankbait cowboy
- Mar 25, 2013
- 620
Actually on the last page also has a good photo of fill nipple and tank in general. I just went and measured it and it is 60x22x6 belly tank and with fitting it is 9 inches high
I was too late with the Miami fabber. You know a good tank is under the deck.
Did you have an eye peeled for the Water Mounties? LOL
The 40 pin holes would be optional add-on cost if you want them back.![]()
It wold add about 40 yrs to the delivery time as well I understand.
Sorry to here about the extra cost. At least you are done with this chapter of the build. I noticed in the first drawing it says the pick up will have no screen?
You lucked out with that much mono wrapped around the shaft. Hope your lucks holds.
It doesn't look like the PO used any grease on the splines.
Come on GA, this motor was owned by a farmer up here, what's the chances he would have grease, let alone put it on something
Glad to see the line never got to the seal Rob.
