The worst of luck, transom damage
NorCal408
Ok, ill try to make this as short as possible. After receiving my 79 Welcraft, with a small block chevy 350 and a volvo penta from my father as a gift, i quickly learned that a lot of work as needed to get this puppy up and running. i am NO MECHANIC and a wont pretend to be one. i do know that there was water in the engine, which was fresh water, not salt, the fuel pump was shot, the water pump was shot, tones of electrical shorts, mis-wiring, etc etc etc... the volvo 280 outdrives lower end was shot because a gasket that held back some oil from the top end to the bottom end deteriorated and was then ran, buring up the lower unit. Anyways, the 350 is now running like a beast, the outdrive was replaced and works like a champ.
Here is where the story gets interesting and SAD.
I decided to take the boat out this sunday . But before, i was to meet up with a friend and change the oil and oil filter at 9am. Well, after arriving to my friends place, we heard that a really close friend of ours took his life at the age of 24. (NEVER TAKE YOUR LIFE) Well, after a couple hours, we decided that the best thing we could do was to get this boat running, go out and see if the boat floats, drop a couple crab pots and take our sadness and anger out on the fish. The problem was, when we went out, we werent starting the engine right, LIKE IDIOTS, and the battery died on us. Since we were on shore, we could have went to the truck to get the truck battery, but like I said, WE'RE IDIOTS. So we drifted the boat back to the launch ramp, backed the truck up and got the boat on the trailer/. The only problem was that the outdrive was lowered in a locking unti, and the manual release for the outdrive to release it back up was on the bottom of the outdrive, IN THE WATER. We would of needed scubagear to release it. The trailer is real low and long so thats why the outdrive was hard to reach. it was decided that we just drag the outdrive out. with the truck. Well, we did that idiotic idea and not the outdrive has somewhat seperated from the transom. When i say partially, i mean on the lower part of the outdrive, the two bolts that connect the transom to the outdrive are pulled out. The bolts on the top are just fine. The seperation between the transom and the outdrive on the bottom is around 1/4th of an inch, and yes, water was pouring out of the transom as we pulled the boat out of the water. Yes, the engine still runs
I have not looked at the boat as it is at my friends house right now, but my questions are.
1. Have you seen this happen before.
2. If the transom was rotten, wouldnt the whole outdrive be torn out with the dragging? only the bottom part seperated
3. what are immmediate steps i can take to dry this sucker out.
4. should i just rebolt the outdrive to the transom and just resin the heck out the bolts
i guess this is a good start to a forum topic
90stingray
Wow! Not sure if its a bad luck problem, or a bad decision problem. Sounds like you have a ton of work to do. How about posting up some pics of your troubles. That will get the best results.
Sent from my DROIDX using Tapatalk
Alwhite00
Master Chief Petty Officer
Re: The worst of luck, transom damage
Sorry about your friend - Hopefully that is what was clouding your judgement and this is not a "normal" occurance.
that being said......
How on earth did you think it would be a good idea to pull the boat out of the water with the drive down? There was no possible way that that would have ever been a good idea. (correct me if i'm wrong) Very BAD idea and I would think between the both of you that you could have figured this out, You definately have some major repairs ahead of you.
Good luck.
LK
Pmccraney
Sorry to hear about your friend and your misfortune the boat. Sometimes our eagerness to get out on the water ends up back-firing on us. We have all made boating decisions that we regret, so don't beat yourself up. Part of the fun is fixing these things up anyway. With that said, I am no iboats expert (in fact, I am pretty much just a clown who hangs out here), but I would be very afraid to do just No. 4 as you mentioned above.
You are probably going to have to remove the drive and maybe even lift your engine and really inspect what damage occurred. The transom is one of the most structurally important parts of the boat (not only to make sure you don't sink, but also because it absorbs a lot of the force, torque, etc.. applied by the drive). You definitely don't want to have a breach or failure in the middle of the lake as opposed to at the dock. Also, I'm not trying to be an alarmist, but you really need to inspect your drive (e.g. your drive shaft), so you want to pull off the drive and inspect the innards (particularly in the upper unit, drive housing). Also, I'd inspect your bellows to make sure they didn't get ripped, torn, etc... You want to make sure the alignment is good, all the bearings are sound and nothing important is bent or broken.
Post some pics of the damage and there are plenty of experienced folks on here who take a visual of what you are dealing with and hopefully get you back on the water.
Ayuh,.... Ya, I've seen it....
Transoms rot from the bottom, Up...
The motor needs to be pulled, then the drive, then the transom assembly...
The rot can be cut out, 'n replaced...
Then the reassembly is the opposite of the removal process...
'course, you'll wanta be Fixin' all the other Problems found along the way...
If yer gonna be payin' somebodyelse to do all this work,...
Figure 'bout 5 to 10 Grand...
Solittle
Check out Coosa as a replacement for the plywood core in the transom. It is a fiberglass composit.
