There is still time to try Boomyals ULTIMATE BRINE
Folks it doesn't get much better than this.<br />It truely does take Turky to the next level<br /><br /><br />BRINE: <br />ULTIMATE BRINE FOR TURKEY <br />Master Recipe <br /><br /><br />1 1/2 cups, Kosher salt** <br />**See notes below regarding amount of salt and types of salt <br />1 1/4 cups, brown sugar <br />10 whole cloves <br />3 teaspoons, black peppercorns <br />1 1/2 gallons (6 quarts) apple juice or cider (non-alcoholic) <br />the peel from one orange or one tangerine (colored part only - not white pith) <br />optional: 3 teaspoons, dried thyme and/or 3 teaspoons, dried sage <br /><br />Combine all ingredients in a non-reactive pot, bring mixture to a boil, lower heat and simmer for 15-20 minutes (partly covered). Allow brine to cool completely. <br /><br />Rinse turkey under cool running water, inside and out (remove giblets from body cavity). Pat turkey dry with paper towels, then immerse turkey in cooled brine.* Turkey should be completely submerged in liquid (place a plate on top of the bird if necessary to keep it covered with the liquid). <br /><br />Cover the pot and refrigerate for 8-10 hours or up to 24 hours. Remove turkey, rinse, pat dry, and roast as usual. <br /><br />*Be sure the container used for brining turkey is non-reactive: use enamel, glass or crockery or stainless steel - never cast iron or aluminum. The pot should be just large enough to contain the turkey (so the brine will be sufficient to cover the bird). <br /><br />** NOTE REGARDING THE AMOUNT OF SALT IN BRINE: A milder brine may be made, which may have a less flavorful result – but if salt is a concern (the entire turkey will absorb only 10-15% of the brine) the amount of salt may be reduced. For the desired chemical effect to take place, however, the proportions cannot be less than 2/3 to 1 cup of salt per gallon (4 quarts) of water or other liquid. <br /><br />**TYPES OF SALT: <br />Kosher salt is the ONLY type of salt to be used in making brine (it is sweeter and more pure than ordinary table salt). Kosher salt is available in two varieties. The most common is flaked salt (example: Morton Kosher Salt) which has been pressed into flakes by rollers. The other type is a four-sided crystal (example: Diamond Crystal Kosher Salt). The crystal-shaped salt measures differently because of its shape. Use about 25% (one quarter) MORE crystal salt than flaked salt when measuring for brine or other recipes. The formula is: 1 tablespoon of regular table salt is equivalent to 1 ½ tablespoons flaked kosher salt, or 2 tablespoons, diamond crystal kosher salt.
Limited-Time
Re: There is still time to try Boomyals ULTIMATE BRINE
Am planning on giving it a try this turkey day, with a twist. In addition to the brine treatment I plan on stuffing the bird then cooking/smoking it on the grill (with a rotisserie) over a charcoal and apple wood fire. Also am thinking about throwing in a bit of Hickory for an additional flavor variation. What do ya think, any one tried this before???
Ron G
After you do the brine,can you still deepfry it?im taking it a brine is the same as a marinating?
tcube
You certainly can deep fry after brining - it tastes great. The important thing is to air dry the bird in the fridge well before putting it in the oil. If it is wet you have a real problem. Hot oil and water don't mix worth a darn.
LadyFish
I was worried about a non-reactive vessel to submerge my turkey in, so I will put mine in a cooler. I'm afraid to put ice in with the mixture, hence diluting it and ruining the chemical reaction that should take place. I guess I will put ice in freezer bags in order to keep it cool.<br /><br />Can't wait to try it. :)
JGREGORY
Link, I'm going to give it a try, I'm frying a turkey Breast for the crew thats coming to my parents. Can't wait to try it. I was just going to inject it with melted butter but this sounds good.
aspeck
I just may give that a try this year. Thanks.
neumanns
All right here's the plan...I didn't go and get all fancy with the apple juice and all but I must confess the orange peel looked like a good addition. and since my bird is still partially frozen I figured why not let the brine thaw it.<br /><br />Soo... the witches brew is simmering now I figure I'll let it set outside to cool good this evening and brine/thaw it for 36 hour's or so in the fridge
SS MAYFLOAT
SOLD! Gonna giver a try! :D Mz Mayfloat is picking up the stuff tomorrow night and gonna eat gooooooddddd Turkey Day! My mouth is already watering jus thinkin about it!<br /><br />Thanks Link :cool:
Boomyal
Ummmmmmmm Ummmmmmmmm can hardly wait. My turkey is going into the brine tonight. Ya'll who shortcut the apple juice are really missing out.<br /><br />Mine will be cooked in the Weber BBQ with various woods to add smoked flavor. I've also done it for oven baked. Either way, watch out.
Parrott_head
I've got a brine solution going right now that I'm waiting for it too cool and then pour over the bird.<br /><br />8 lbs of ice equals a gallon of water. You can take that into considertion when adding ice to the brine.<br /><br />I make a concentrated brine that the ice then tempers down to the one cup to gallon routine.<br /><br />I use a big kettle that I put a lid on and then put in an ice check with cold water left from thawing the birds.<br /><br />One bird is getting the sugar/salt brine and one bird is getting a citrus brine.<br /><br />Bon Appetit'
Boomyal
Just a note for the briners. I am brining the biggest turkey that I have ever done. It is 23 lbs. I found that my SS pot (12" dia) was too big around to allow the two gallons of apple juice/brine to cover the bird. <br /><br />A clean 5 gallon plastic pail(10" dia.)is just the ticket. I put the bird in, wings down so they pushed off into the bottom corner of the bucket. I just had to add another quart of water to get the whole bird covered.<br /><br />Whereas my SS pot fit in the refer, the plastic pail does not. Fortunately it is in the low 30's out at nite and hi 40's during the day so I can just leave it outside in the shade.
Well I just finished the brine at 11pm. It's in the garage to cool down before putting in the fridge.<br />Last year I think I used the optional 3 tsp of thyme and sage.<br />This time I used 3 tsp of mixed Pickling Spice.<br />Sure smells good around here. :) <br /><br />Boomyal thats a big turkey!<br />Tomorrow morning I'll pick the turkey up from mum in laws place and let her sit for about 24 hours in the brine.<br /><br />First time in 9 years I haven't smoked a bird for Thanksgiving! But for just three of us it would have been over kill. We are going to have enough to do in just getting rid of a 13 lb bird between us. <br /><br />Limited-Time<br />Havent tried it over a rotisserie. But thats a good idea and this is the first time I will not be smoking first.<br /><br />PS I always add (when smoking) 1/2 bottle or 1.25 oz of (Wrights) Liquid Hickory smoke to every 2 quarts of the brine. <br /><br /> Ron G <br />You are correct.. let everyone know how it turned out.<br /><br /> tcube Answered that one. Be carefull so you can report no house burn't down :) <br /><br /> LadyFish<br />I was worried about a non-reactive vessel to submerge my turkey in.<br /><br />Thats just for boiling / cooking the brine.<br />Sorrey I didnt catch that earlier.<br /><br /> Boomyal <br />See what ya started! ;) <br /> It's a Good Thing <br /><br />My Gal Martha! :D
Limited-Time
Originally posted by Boomyal:<br /> Whereas my SS pot fit in the refer, the plastic pail does not. Fortunately it is in the low 30's out at nite and hi 40's during the day so I can just leave it outside in the shade.
Boomyal, <br /> Where abouts you going to keep that bird outside? JIC I "happen" to be in your area, I'll check on it for ya...... ;) ;) :) :D
aspeck
Did my brine and added a little Tumeric and sage to it. Left it set all last night and till Noon today. Cooking my bird now (going away for the day tomorrow so turkey at home tonight). It sure is smelling good.
aspeck
Just pulled it out of the roaster. Flavor is good, but what really made the difference is how juicy it is! I usually don't care much for the white meat because of the dryness. But this is very, very moist! In fact, I had juice running down my arm when cutting and tasting the breast meat. And yes, it was fully cooked!
Ron G
Im not doing a turkey this year for thanksgiving mom is,but were having a party saturday night im was thinking about doing 4 whole fryers of chicken in the brine and beercan them with smoke,should work real good with chicks.
Boomyal
Just went outside, after two days of soaking, and checked the temp of my brine and turkey. It sat on the shady side of the house since Monday nite. My handy dandy infared thermometer shows the brine and turkey to be at 39F.<br /><br />I've decided, due to the size of the bird, that I will stick it on the Weber rotisserie as I think 23 lbs is too big to sit on the grill with the charcoal off to the sides of the kettle. Plus it would be more difficult to add new coals as I'm sure I will have to do during the course of the cooking.
LadyFish
Mine has been in the brine since yesterday. I tried the apple cider this time and followed the rest of the recipe to a "T". I'm fixin to take it out of the brine and stuff it. I can't wait to try it in several hours.<br /><br />WARNING FOR NEXT YEAR: If you use apple cider instead of water or apple juice, DO NOT leave the stove unattended while you bring it to a boil. It makes a HUGE mess when it boils over which takes only seconds after it starts bubbling. :rolleyes:
