Thermostat Discountinued, now what?
calincoltsdad
My yamaha dealer says the 140 degree thermostat they ordered is discontinued. I can't find one under 160 anywhere. What do i do now? Has anyone used a thermostat restrictor plate in place of a thermostat? If so do they work?
Don S
Re: Thermostat Discountinued, now what?
Exactly what engine, Year, model number, etc. are you looking for a thermostat for.
bayliner12
if your in warmer water, i'm just asking here, do you really need a thermostat?
Bt Doctur
Just a guess, but being a GM based motor, shouldnt one from a Merc do the same thing.Cant see the therm being physically different for a yam.
Don S
Yes, you need a thermostat, without it, part of your engine will be cooler, The part around the temp sender. the back of the engine will overheat and you will never no it.
Yes, that thermostat (YSC-10090-00-AC) is NLA from Yamaha. I really don't know anything about Yamaha IO engines, so can't even tell you what a good replacement is.
With any luck, Capt Ken will see this and help you out.
Don S
Not sure the thermostat is the same size as a Merc or a Chevy. due to it being in a Yamaha thermostat housing.
#28 is the thermostat
attachment.php
calincoltsdad
The yamaha thermostats are longer because the housing is taller and that allows it to sit farther down. I have a Merc 160 in now but its not working correctly. My local race shop has the restrictor plates that take place of a thermostat, so I'll go pick one up a try it. Just not sure what to try.
Ayuh,....I'd just Sell the boat,+ buy a new 1 that you can buy Parts for....
