Thermostat housing spacer
obezag
Is there a trick to removing the thermostat housing spacer above the thermostat? I don't want to damage anything trying to get it out. It's a Mercruiser 5.7L (seawater system). Alpha 1 Gen II sterndrive.
Thanks in advance for any help. Gary
tystick
Re: Thermostat housing spacer
no tricks for that one - after you remove corosion
Don S
Do you have a serial number, or even a year will help..... Some..... there are several different styles of housings.
