fmt2bx
- May 27, 2015
- 217
Hi,
Don't know when that thermostat had been replaced last (if ever) but it must have been many many moons ago. I had the help of my neighbor and took us a while to remove the top 2 screws using an impact driver. We couldn't get the 2 bottom screws off, lots of corrosion on the heads and we had to cut them off eventually.
The thermostat was busted (see pics) and now we have to remove the studs. Soaked with PB blaster and DeepCreek, we'll see what we can do tomorrow with some vice grip plier. Hopefully we'll be able to get them off.
Should I use heat if necessary?
Any suggestions?
Thanks.
Cheers
Frederic
Any suggestions?
Thanks.
Cheers
Frederic
