Thermostat/temp
Hi all,
I just replaced my thermostat (Merc, 160F) and gaskets on my 5.0 MPI and then ran it on muffs to test my water distribution housing after fixing it with JB marine weld (success!).
After getting up to temp, my gauge levels out just above the 175 mark. Assuming it isn't supposed to go above 160, is this an issue? If so, something tells me it could be a faulty sensor or gauge considering my last tstat last year did the exact same thing. Should I be concerned?
I've uploaded some images of the gauge with the boat off then at temp:
Any insight is greatly appreciated!
Thank you.
alldodge
Verify with a IR temp gun on the thermostat housing but I've read many post here and FB about the quad gauges on a Chap
Hope your trim gauge is not accurate because should not run a motor with the trim that high
badrano
Temp gauge reading is the same for my 6.2 MPI with 160 thermostat whether on muffs or in the water. I know the voltage gauge is a little off on my boat....yours looks like what I would expect.
So an IR temp gun on thermostat housing should read 160?
Yikes, it was up all the way as it's trailered but I guess I should drop it down when starting it on muffs 🤦🏼‍♂️ I never thought about that. Is it because it could cut off water supply?
Thank you for the heads up.
This makes me feel much better, thank you for your input!
alldodge
It should read close to that
It's real hard on the bellows and the U joints
Should be no higher than the trim limit
Got it, I'll check with the thermometer.
And that makes sense .. I feel like an idiot, but at least I did just rebuild and service the entire outdrive. I will make sure I don't do that again! 🤦🏼‍♂️
Is it OK to store it with it trailered up all the way? As I don't imagine the strain on the bellows or U joints would be much different when it's running on muffs in idle vs just sitting there with the motor off, would it? Or strictly just when transporting it and then drop it down a bit again (and not forget to bring it back up 😅)
alldodge
You can store with it full up, but many including my self do not.
Storing it full up keeps the bellows stretched out. Over time it will cause cracks sooner. I lower mine down as far as possible to make it last longer. I pull drive every year and check everything. Replaced my bellows for first time at 21 years and it didn't need it then.
https://forums.iboats.com/threads/bravo-itis-fix.680176/
Scott06
No with a 160 stat the engines run about 170-175 so what you see is completely normal . My 5.0 with same stat runs the same temp.
alldodge
My Rinker 454 and Formula with 509, 530 HP both had 160 Stats, and both never got above 160 unless unless I'm running WOT for a long period
Could it be the 5.0 in particular that has this quirk? I have no idea.. seems odd but at least doesn't have me as concerned now.
tango13
My temp gauge for my 7.4 doesnt have #s, just low and high. Mine always is a tad over the middle - no clue what temp its saying, but I have a 160f tstat and im always comfortable if the gauge reads the same spot when its up to temp. Also had an older 5.7 in another boat that always barely got over 140 on the gauge - it was consistent so i never worried.
If yours always lingers at 175, your good to go.
