replaced thermostats & pump/impeller ( had a high temp alarm). Ran into some trouble. Hope someone can offer some advice..
I would apprechiate any help...
Changed the thermostats & noticed that the old ones were STAINLESS STEEL & the NEW ones are BRASS...
I am pretty sure these are ORIGINAL as the paint was not broke off the bolts yet..( yr 2000 135 Optimax)
I got these from iboats. Here are the part numbers:
Sierra # 18-3553
Replaces Mercury/Mariner 75692
added info.
parts are listed on iboats as "V135 A904646 & UP 75692 18-3553 "
My serial number is OTO66263
Since installation,I read that the brass ones are 120 degrees & the Stainless are 142 degrees... Will either work or did I just install the wrong thermostats....)
Thank you very much...
Sierra # 18-3553
added info.
