Thinking of removing brakes - double axle with 19 Cape Horn
H20Rat
Re: Thinking of removing brakes - double axle with 19 Cape Horn
I realize maintaince now. This is adding up quick...
The lines are probably a write off also... Once things are rusted up that bad, you also have rust in the lines. Yeah, you MIGHT be able to flush it out, or you might end up with some flakes that wedge up in your new brakes. Far easier (and cheaper in the long run) to scrap that brake system and start over.
Also, welcome to boating! The cost of the boat is the down payment...
bruceb58
switch to disk brakes. the whole kit is under $600 which includes everything from the coupler to the hubs
Boat Trailer Brakes
I agree. I have disk brakes on mine. I would never put drum brakes on a trailer that gets used in salt water.
Get Kodiaks. Stay away from Tie Down.
big_chief
UPDATE: I ended up swapping to disc and the job is nearly done... a few things to finish today... new actuator, new lines. I also swapped the axle, shackles and hardware while I was doing the job... as well as swapped the hubs on the other axle.
1. I thought about the rotation to mount the caliber... and ended up putting on the rearmost (90 degree, 3 o'clock). When I lowered the rig, the top caliber mounting bolt was within 1/4 inch of the frame. Luckily, I didnt have time to bleed the system and even install bearing covers, so its still accessible this morning to adjust. I plan to just rotate the assembly one more level, which will put the caliber at 135 degree (4 o'clockish) closer to the road. Is there any concern with the caliber being this low? Besides possible road debrie... what about function, since the lines, cylinder are now lower? Seems like a simple answer, but figured I would ask.
2. I had torque specs for the caliber mounting bolts (40 ft/lbs). What about these specs... The mounting bolts that hold the disc flange to the axel? The U-bolt kits that bolts the axel to the springs? And the bolts that bolt the spring to the trailer frame/tandom bracket? Everything has lock washers.
3. The hub castle nut... (think of "spires" on the castle nut for reference). When I installed the hub and tightened the nut, then backed off one click (spire). Seemed to rotate the wheel just fine. If I backed off 2 clicks (2 spires) it gave the wheel a slight 1/16 inch wobble (or caster). I went with 1 click... but didnt know if that might be too tight?
Thanks again... I'll post pics and review when done... I went with Deemax brakes (great price). Heard from alot of people they were engineered by a Kodiak guy and they work great. A local installer said he has been using them for years on saltwater installs. Heard lots of mixed reviews about Tie Down though.
Thalasso
Nothing wrong with the (4 o'clockish)location. There are auto's out there with the same setup.
Lou C
Its OK to do it that way, the only issue may be when you bleed the brakes, bleeding works best of the bleeder bolt is at the highest point so the air bubbles can escape. I've heard of people temporarily positioning the caliper higher on the rotor just to bleed it then re-mounting it in the proper location that gives you clearance.
