NEWBEBOATER
- Apr 23, 2008
- 19
Re: three brass screws
thank you to everyone who has helped me, and let me know promptly of how dumb i was for dry runs....
here are a few pics of the impeller and the housing, there was a small amount lubricant in the case, and the flex of the impeller seemed good to me. i cleaned it out a little and inspected further, looks good. i must be quite lucky
the reason i was not sucking up any water appears to be because the water
inlet was not fully submerged and could not build pressure.
i also found all the drain bolts and tightened them.
i looked inside the cooling area. the antifreeze looks very consintrated.
i heard some one mention i should run it with fresh water? any comments,
hot do you drain the antifreeze?
