No base timing for the TB4 ignition.
Great, you're almost ready to light it off! Don't forget you have to run water to the drive whenever the motor is running.
Sorry Don im a little confused lol . how the heck do i set the timing then if there is no base timing? just want to make sure i get it right since this is not the stock 260 hp any longer . different compresion different cam all different . thanks again
You just start the engine, hook up your timing light and move the distributor to the proper timing. There is no special base timing "MODE" of any kind on the TB4.
