Snowmann40
- Aug 13, 2012
- 44
Re: thunderbolt 500 please help with gear adjustments
I have the nut pretty much in the same place as your picture, you can see it in pic number one. The nut that's a little higher in the same picture is what I have set up to change gear with. The nut is attached to a rod (you can barely see it because of all the stuff in the way), this rod moves on the rail where the cables are attached, and the other end where the nut is attached goes straight to the shift rod, you can see it better in the third picture. I've looked on top side and bottom, and I can't find anything that remotely looks like a detent.
I found a part number 53889, punched it on ebay and it returned the exact shift rod I have.
http://www.ebay.com/itm/Mercury-out...3889-73471-22-5-60-65-85-115-hp-/160695590296
