lukecono
- May 23, 2023
- 57
Hello, I just replaced my ignition module after I burnt up the last one along with the coil. I got the boat running fine but I still have all ignition component getting warm. Could just be engine room warm but I wanted to ask to make sure... it's bearable to keep hand on coil and module but definitely hot. The ground wire coming from my thunderbolt 4 module where should I have that grounding to? I also have a ground wire that is between one of my 3 mounting bolts that the module is fastened by on the manifold. Should I have any wire be grounded between those mounting bolts? I also had aluminum spacers between the manifold and module but changed to nylon spacers, trying to avoid any metal making something funny happen again. I don't want to keep burning 150$ for modules. Thanks in advance!!
