nitrous_bob
- Apr 27, 2016
- 2
Ok I've run through the flowchart, about 10 times. With the key on, I have 11.8V on both sides of the coil. The batteries are at 12.4V
The red/white from the coil shows 10.6V
I replaced the coil and ignition sensor anyways.
I used another module that is "supposedly" good from a running motor
The only part of the flowchart test I'm unsure of is where you use a spark gap tester on the coil and unplug the green/wht wife from diz and rapidly strike it to ground.
Wouldn't it be the same thing with a wire from coil to ground ? Or for that matter a lead from the green/wht wire right to the coil tower ? I'm no electrician but I can trace wires and follow directions. I still have no spark from the coil when it turns over. The only variables I see , is that the module I tried is no good, or I'm totally lost trying to spark the green and white wire. Help me out please.
The boat was running for over an hour, stalled.... Now no spark
