Fishermark
- Oct 19, 2003
- 5,617
I'm helping my brother with his new project. He has a mid eighties vintage Mercruiser Chevy V-8 (305 I believe) with an alpha 1 outdrive.
The engine was shot, so he rebuilt it. It originally had a points ignition, and I have a Thunderbolt IV distributor that I salvaged from another engine a few years ago. I have never used the Thunderbolt IV, and I am not sure if I have the correct wiring diagram handy, so I have a few questions....
From the picture below, here are my questions:
1. The black wire going to the distributor cap hold down screw - is that simply a ground wire?
2. There is a white wire with a red stripe on the left terminal of the distributor body, and a white wire with a green stripe on the right terminal. They are both loosely attached, so I don't know if they are supposed to go there or not. Are they correct?
3. From the module, there is a 2-wire harness with what appears to be a purple and grey wire. Does that go to the shift interrupt switch? If so, is that a typical shift interrupt that simply goes to ground?
4. The short black wire from the module - does that simply go to ground?
Any help would be appreciated! And even a link to the appropriate manual or wiring diagram. Thanks in advance.
