tilt and trim motor removal
bpartri
Question---What is the easiest way to remove a tilt and trim motor from a 1993 85 HP yamaha motor? We can not get the screw out of the back corner. Thank you.
rich_benson
Re: tilt and trim motor removal
Get an impact driver, I had the same problem with the same screw...
Use the piston to pull the unit down towards you so it is easy to access the screw, then smack it with the impact driver, many times to loosen...keep working it out, it will come but it took a full hour.
JUSTINTIME
PB blaster and impact driver like mentioned above
