Tilt and Trim
cisnet
Power tilt and trim crapped out any suggestions on where to start? And how does the wiring go again if i just want to lower it cylinders stuck at the top
Chris1956
Re: Tilt and Trim
Normally PTT units have manual releases. If you post year and HP of the motor, we can give more factual advise.
emdsapmgr
Re: Tilt and Trim
Do you hear the trim motor running when the trim switch is in the up and down positons?
ccnstlr
Re: Tilt and Trim
Read here. May give you some insight.
"http://www.brokeboats.com/trim.html"
cisnet
Re: Tilt and Trim
I tested it today have power right to TT motor but think its burnt out
Chris1956
Re: Tilt and Trim
ARCO and Sierra make aftermarket replacement PTT motors. You might see if they have one for your model.
