Tilt and trim
vit
I have power control at motor, but not at hand throtlr. can some one please tell me if it could be a fuse, and if so will it be in hand control unit?
itsaboattime
Re: Tilt and trim
What motor and control unit are we talking about here? A model number would be helpful. There is a tilt and trim switch that has a habit of crapping out, but we need to know which one you have in order to help you.
will62
Re: Tilt and trim
As itsaboattime said, need to know your OB model, or at least year and HP. Then check to see if you have a 2 wire or 3 wire trim motor. I'll get you started with some info on the 3 wire motors. Much will be similar to the 2 wire motor, until you get back to the solenoid(s). If I understood you correctly, you have a trim switch at the motor, and it is working properly. That tells me that the problem is probably not related to the solenoid(s). You'll need a multimeter to do the tests in the photo below. Hope this helps.
