tilt on throttle control won't bring motor up it ,but will bring it down
butchy54
the tilt up doesn't work on the throttle control it works for the down I can bring up on the engine and the front of the boat.My question is there a quick fix for this with out spending 400.00 for new throttle control.1990 evenrue VRO 40hp the throttle control has a rubber swich on the arm which controls the up and down.As Always Thanks for any help you guys can offer Art
dingbat
Re: tilt on throttle control won't bring motor up it ,but will bring it down
It could be one of two things.
It could be a loose wire or bad contact on the helm switch. Been there done that. Had to replace the switch $60. Or it could be a bad or loose "up" relay on the motor. Been there done that too. Loose in socket. $0
