Tilt only works making a left turn
djarvis1959
2003 honda 200hp outboard My power tilt only works while turning left. Works fine from the switch on the motor but not throttle switch Any ideas ?
dingbat
Sounds like the wire (cable) from the throttle switch back to the motor switch is damaged.
Guessing the insulation is worn through from rubbing on something. I would focus in the area where the wire (cable) enters the motor.
Pull the throttle switch and check for continuity as you move the motor back and forth (left and right). Shouldn't be hard to find
