Tilt/ Trim dosnot respond.
twintrades
Hey i have a 1979 mark twain with a 165 I/O.
Last yr the Tilt/trim would not respond at the end of the seson so i just put a ratchet strap on for th winter. Now i have to fix the problem.
When i try to run it the unit wont make any noise pr go up/down. But if i push boath buttons to make it go in trailer mode it will click. Could it just be the selinoid ?
When i try to jump it nothing works but then again mabey im jumping the wrong wires.:p
Any one ?
stonyloam
Re: Tilt/ Trim dosnot respond.
If nothing works, first thing to check is the fuses. For your vintage boat go to "adults only", #9 Merc Manuals, download Manual #5 for your outdrive, look at the power trim section,it will tell you how to troubleshoot your system. Good luck.
rocket1968
COuld be solinoid or connections. I have the same engine and am in the middle of replacing the hydraulic trim pump. check your connections since it is the easy fix and then troubleshoot. I had a similar issue and it was a bad/frayed wire. I would get a click and then sometimes full function.
Now if you have the instructions on how to rebuild one of these things, that would be great! Good luck on your repair.
Don S
You actually need manual #4 for your outdrive, 5 is for a TR.
Section 2 covers troubleshooting, for more details, download manual #6. Much better detail. Still in section 2.
twintrades
Thanks ill look into that. I forgot about those.
