I have a 1993 115 Merc and the tilt/trim will not lift the motor up. It works bringing the motor down but when I try to lift the motor up the relay just clicks and the trim motor does not run. I thought I had a bad relay so replaced it and same results. If I switch the relay's around, the down just clicks and the up runs the trim motor but does not lift the motor. I took apart the trim unit and replace old dried out "O" rings so might need to add more fluid. Anyone care to give me some suggestions to get this working?? <br /><br />Thanks in advance!
