Hello helpful boat mechanics,<br /><br />I have just installed a used tilt and trim. Rams and hoses look good, but I'm having a problem with the electrical circuits. This is a 1980 Merc 50 hp. It uses the 3 button controls, IN (down), OUT (up), and UP (I think?). The up is equivalent to trailer. When I press the IN button the trim motor works fine. However, when I press the OUT nothing happens, and when I press the UP (trailer), the solenoid clicks, but the motor does not run. I used the Merc trouble shooting guide for when neither the OUT or trailer circuits work (by pass the limit switch, etc), and the voltages look fine. The motor should be working in this procedure. Any suggestions? Since the pump motor works in one direction,I'm inclined to think the motor is good, but if I was sure I wouldn't be asking for help. Any suggestions anyone????<br /><br />Thanks,<br />Barry
