Tilt trim switch wiring
Poormansboating
Should get it all buttoned up tonight and gonna take it for another test tommorow fingers crossed I'm not paddling again. Lol
puffitu
My first force melted a piston but still hadn’t had to paddle; ) it limped me back to the dock..!
Poormansboating
Well that failed put carbs back together. Put them on started it up and the middle carb is leaking gas from each side there is a hole on both sides and both are leaking. Any ideas what could be causing this. It leaks big I just prime it with primer bulb
Poormansboating
I'm sure I messed something. Cleaned it all out blew out with compress air. Started ok but now this gas leak. Ahhhh
Poormansboating
I made another post on my issues but just keep you updated. I found that my float needle has a rubber tip that seems to be boogerd up. Trying to find one but the ones im seeing online don't have a rubber tip any suggestions Buddy
jerryjerry05
Put on a pic of the needle next to a ruler.
I'll see if I have the right one in my stuff????
It's at 64 posts, the last are about carb stuff, might be time to start another thread??
OOOPS!! I see you already did that. :(
