tilt @trim troble.
narvlebenoit
I have a inline six with two rams for the trim and the motor and oil resover are togehter with four hoses. changed all the hoses was working fine then just ouiet.Oil is full Changed soloiends didnt help could they get air lock or did motor give out can you change just the motor dont look like it to me.
Chris1956
Re: tilt @trim troble.
If the PTT motor doesn't run, that is a motor problem. Those PTT motors have a bi-metal overload (circuit breaker) inside the motor casing. Maybe it opened and got some dirt to keep it from closing.
Connect the battery directly to the black (-) and blue wires (+12VDC), bypassing the solenoids and other wiring and see if the PTT motor spins. if not, you need to take it apart and check it over.
narvlebenoit
Thanks I TOOK THE COVER OFF AND THE BRUSHES WERE GONE ODER NEW ONES WAITING FOR THEM TO COME IN THANKS AGAIN CHRIS1956
