tilt/trim
hey guys! i am a new to me owner of a 1993 sunbird corsair 187 sl! love the boat! but when i went to trim it up it clicked and then did nothing else. it has been sitting for a year and worked fine before. with it clicking one time when we tried to trim it makes me think it blew a fuse somewhere.is there a fuse panel anywhere that i can check or something else that might be wrong? i am new to boats so dont know much about them. can i get any input on what you "professionals" think? any input wud be appreciated!! Thanks for all you do!! by the way, it has the omc 4.3 cobra engine. if thta helps!!
Don S
Re: tilt/trim
There are a couple of 50A breakers on the engine, one is for the trim system. Check them with a meter to make sure they work, don't assume if it's pushed in it's ok.
Here is some info on testing the relay box on the pump itself.
Drawing wrong and removed
Re: tilt/trim
Thank you sir for the fast response. I will test them as soon as I get time this weekend. Might be getting back with you if thats not the prob!! thanks again!
Don S
Re: tilt/trim
Come back one way or the other and let us know what the problem was. Someone else could benefit with what you find.
Re: tilt/trim
OK Mr. Don, I reset the breaker on the engine. Then tried to trim again and the trim motor clicked bout 5 times then tripped the breaker again. Suggestions?
Re: tilt/trim
Ayuh,.... Welcome Aboard,.... Remove, 'n clean the wirin' connections, Shiny metal Clean, 'n try it...
If that don't help, pull the trim motor, 'n bench test it...
Re: tilt/trim
yes sir! welcome aboard to me! lol this my first boat, so i am new to it all!! i will get on that today! will let you know what it turns up! shiny metal clean, here it comes!!
Don S
Re: tilt/trim
Remove the two motor wires (C&G in the drawing above) and jumper them directly to the battery and see if the motor runs. It could be locked up.
Doesn't matter if which one goes on which battery terminal, all it does is reverses the direction of the motor.
Re: tilt/trim
Alrighty!! Jumpered the 2 power wires. Still just clicked away!! So, I'm taking it as the motor is locked up! Direct me to a descent priced trim motor. Thnx!!
Re: tilt/trim
Ayuh,.... Follow the links at the top of this page, to Here...
RRitt
Re: tilt/trim
It seems to me that you identified the boat but maybe not the trim motor itself. Is it known for absolute positive to be a 2w trim motor? some 3w motors only have 2 wires showing. they use a frame ground. If it was 3w motor then clicking and sparking without any spinning would be a normal reaction. If it was a 3w trim motor then you have to ground the frame and touch 12Vdc to only one wire at a time.
Re: tilt/trim
Well, it's all Greek to me! It looks like the pic above. Only the relay is attached to the trim motor itself. I will say, when I jumper wired it, it was clicking with only one wire attached.
Re: tilt/trim
Yes sir I did. The only thing different from the diagram above is that G is doesn't run to the pump. The one above it does. G is a small black wire on my setup.
Don S
Re: tilt/trim
I don't have a clue why you have a black wire anywhere than what is shown in the drawing. But its not right if that black wire is actually a ground wire. It MUST be wired like the drawing if you want it to work.
The fact that the motor clicks when you touch one wire, indicates the motor is shorted to ground internally.
Re: tilt/trim
Well, nobody has changed the wiring. And it wont wire up the other way, cuz the connectors aren't the right size or wires long enough. It has 2 big terminals and 3 small. The 2 big wires and terminals go straight to the pump. The other small to switch.
Don S
Re: tilt/trim
We have one disadvantage, we can't see what you see. Post a picture so we can see what we are dealing with.
Re: tilt/trim
sorry, my internet has been down all day. was trying to post one before you requested. but here it is. this on the top side of pump. thanks for all your help already and your patience.
Don S
Re: tilt/trim
Well, my drawing is wrong, and I removed it. Looks like I picked the wrong diagram to copy.
If you jumpered the two wires going to the motor, then you need a new trim motor.
