Tilt Tube REALLY stuck. Cut it?
CheckmateEnticer
I have a 1990 Evinrude 150XP i got for fairly cheap but the little things are starting to add up. I plan on fixing up and painting this motor and rigging it to my boat over the winter when I have some down time. It came with controls and dual cable steering cables and helm. One cable worked and pulled right out when I removed it from the donor boat but the other had to be cut with a sawzall. After heat, PB Blaster, and increasingly large hammers I am sure that both the cable and the tilt tube will not come out. There is enough gap between the two brackets that the tube goes through to fit a sawzall blade. My plan is to cut both sides in order to seperate the 2 brackets and then maybe use a punch to remove the remaining tilt tube and buy a new tube. Anyone see anything wrong with this plan or have anything to add? Thanks, Scott
phillnjack2
Ensign
Re: Tilt Tube REALLY stuck. Cut it?
No it sounds like decent idea to me.
if you can get a saw in the gap, and your gonna get a new tube, why not just cut it off and do it on a bench the easy way.
get a stainless one, they are woth it in the long term and not too expensive neither.
but with a good grease up every couple of months they should stay pretty good anyway.
let us know how you get on with it
phill
durban
Master Chief Petty Officer
wot ever material tube you get its got to be 22.2 mm diameter OD
