Sunsetrider
- Jun 12, 2011
- 299
I'm reaching the point where paint choices will have to be made and despite long hours perusing the wisdom of the forum I need the straight-up goods . . . on
1. pre-paint prep of the hull an and and interior,
2. undercoat? what brand and exact type?
3. Finish coats? same question.
I intend to go with a white hull and a color stripe/topsides, something light in color and available off the shelf from Rust-OLeum. I plan to paint with 6-inch foam roller/sponge tipper.
The pics below (still cannot get the hang of full-size pics, whether from my 'puter or from photobucket) show the state of the paint after sanding with 100 grit (still a few rows, and the bottom, to go). The topside has been sanded and is quite smooth. I understand the existing paint structure can serve as primer, so I guess i need an undercoat before the color coats. Am I guessing right? I wonder what specific type of paints are successful? I wonder whether the hull at this stage looks good enough to paint (except the bottom 2 strakes which aren't done yet).
The inside of the hull - I am thinking of gray spray paint, after a bit of scraping and sanding to get the loose stuff off. Have to know what type to go for.
I have to admit to being prepared to go for less than perfection as far as below the waterline is concerned. However I should note that all my boats stay in the water pretty much all summer long (fresh water, pretty clean since we drink it after filtering).
Thanks!
Thanks!
